Home AMX Technical Discussion
AMX transmit question
I have an NI-3100 and sometimes the device is doing a transmit in port 1 of the device but nothing is connected to this port.
What can be the problem?
  • udiudi Posts: 107
    how can I do a reset to this port?
  • Jorde_VJorde_V Posts: 393
    udi wrote: »
    Do you mean rs232 port 1? (the actual port 1) or port 1 of ir/whatever?
    I've never seen that it does but I'll check on my 2100 here. Else it might be in your code.
  • udiudi Posts: 107
    I meant rs232 port 1
    It's either stray code or something wrong with the controller. You can try resetting it by issuing a reboot to the controller device number via Telnet (reboot 5001), but I strongly doubt it will make a difference.
  • udiudi Posts: 107
    thanks I wiil try what it
