RS-485 cable
Hi all,
I have a RS-485 ( A, B, GND ) interface embeded in a Lighting control.
I want to connect to NI-900 serial port.
Could somebody please let me know the correct wire cable.
Thanks in advance
  • The wiring for the AMX 9pin Ports is contained in the NI900 h/w reference guide - Page 18 to be exact.
    With RS485 you need to be aware that A&B are sometimes referenced differently with different manufacturers, if things are not communicating, try swapping A & B over.
    HTH
  • jjamesjjames Posts: 2,908
    Also, don't forget to send the 485 ENABLE command when you set the baud for the device.
    Example: send_command dvPelcoD,"'SET BAUD 4800,N,8,1 485 ENABLE'";
  • I will try do it.
    Thanks folks.
