Lutron module p5 117 stop working
Hi all
I am having an existing home with huge huge Lutron (167 keypads) system that used to work with the duet module p5 version 117.
After the Lutron man came and update the controller, the module is not working.
I tried a lot of things, reveresed my code, get back to a 100% working code, nothing.
The problem is that he did firmware upgrade to the controller to from 1.32.1 to version 1.49.1.
I have ping to the controller, "amx, control" is defined as it should on link 9.
The Lutron program is working good with the controller.
Only the module stooped working, looks like there is not connection but its hard for me to debug it...
Any ideas before I am loosing my hair?
Ady.
    Did the password change on the Lutron controller?
  • adysadys Posts: 395
    ericmedley wrote: »
    Nope
    I can login with Telnet with "amx, control"
    in the module it goes
    SEND_COMMAND vdvLights, "'PROPERTY-Login,amx,control'"
    Been like that for 3 years
    I'm still using the old skool rs232 module (non-duet) and have kinda built a work-around to get it to work with IP. it still works as far as I know. I don't have any angry clients standing outside my door with pitchforks and touches.
    There haven't been any control changes in Lutron from v, 1.32 to v. 1.49; I've upgraded many without issue. Unless the Lutron guy deleted the login, there is no reason it should have stopped working. Did you do any AMX upgrades while you were at it? I've had that happen more times than I can count ... and AMX update breaking a Duet module.
    Another thought though ... did the IP address on the Lutron change? By default, they are DHCP, not static, and the update might have forced a new address. I'm thinking there is a real strong chance of this ....
    DHawthorne wrote: »
    I have the same login as it was, he didn't delete it;
    The ip is the same.
    I just can't connect with the module, with Telnet its ok.
    If you aren't talking to the module, it's almost certainly a NetLinx firmware incompatibility with the module. Telnet the master, and do a "show system" command. If you don't see any device numbers in the 40000 range, that's the problem. Unfortunately, there is no hard and fast solution except to make sure the master firmware and the module are completely up to date. I have had one or two cases where the module hadn't been updated by AMX and simply would not work with current firmware, and I had to make my own NetLinx version.
    DHawthorne wrote: »
    this has happened to me too with a pool controller module. I feel that if AMX is going to make a module, they should offer a Netlinx version for just this reason. If they are not going to keep the Duet modules up to date, then we're bound to hit these walls.
    DHawthorne wrote: »
    Sorry for the late response.
    This is the case, I don't see any devices in the 40000 range.
    After duet firmware update the module is working!
    I have few issues with updates, but better than before.
    adys wrote: »
    This is the case, I don't see any devices in the 40000 range!
    I will update everything and update the solution here
    I got bit by this the other day. I was making a few changes to an older system with a 4100 in it. I was adding our CCS module and a #*(&$&*#*@ duet module. Lo and behold, the 4X,XXX range didn't show up. I upgraded the firmware and all was well.
    ericmedley wrote: »
    Yes..
    The problems is that this module is not something to begin with... I will have to rewrite it one day
    Ok, all commands are working, but no notification from module, at all, nothing.... :(
    adys wrote: »
    No notifications in NS? This might be a NS version vs. NI Firmware version issue.
    ericmedley wrote: »
    Ok back to life!
    I have update this firmware
    http://www.amx.com/techcenter/downloadConfirm.asp?fn=/assets/firmwareFiles/2105-04_NI-X100_Master_v3_50_439.zip
    and this
    http://www.amx.com/techcenter/downloadConfirm.asp?fn=/assets/firmwareFiles/SW2105_NI_X100_Device_v1_20_7.kit
    When ever I am uploading full source include the jar file, it stop working, so I needed to update firmware again...
    so now when I am loading I am only updating my code.
    thanks for all the support, you really saved me!
    I am not recommending this module to anyone!
    Ady.
    adys wrote: »
    Ady.
    Another satisfied duet customer!
    Glad you got it up and running.
