Web Product Searches
Suzanne Youngblood
What manufacturers' web sites have the best product search tools? What do you like most and least about those search tools? How would you ideally like to search for products on amx.com (your current options are to use the Product Finder or the AMX Web Remote search field - both on the Dealer home page)? Your insight are most appreciated!
Suzanne
Suzanne
Extremely easy to find anything you need fast by offering multiple methods of search (by model number, by function, by document type, etc.) and when showing a product's page they also show related products like rackmount kits, power supplies.
Almost anything you need to support current and old products is available.
They also provide great articles on the technologies they sell, together with troubleshooting guides.
It's too difficult to find items unless you already know specifics. Say, for example, you are looking for a specific AMX product, but you don't remember the model number, or even if it is still a current product. Where do you look? When going through the product tree, the target box lists model numbers with no descriptions - you have to click each likely candidate in turn and read the full description. A search may or not be helpful, because if it is discontinued, the search will come up empty. If there was a browseable listing with all the products and a summary description, you could at least scan the category and see what is there. The full official price list has this information in that kind of format, but that's not convenient if I'm at a customer's house looking for a solution to a job issue.
This is a much bigger problem for Tech notes. There desperately needs to be an index of all the available notes; searching only finds things if the search term you use is worded exactly the same as it is in the notes. Often I'll find my issue was addressed in terms I never would have thought to express it in, but by the time I stumble across that, I've already been forced to develop another work-around that consumed my time unnecessarily. And what about just being able to pre-empt an issue because you read a tech note in advance of having had that particular problem?
Extron comes to mind as one company that does this. An example of this on the AMX site would be the new Lutron H48 interface. If I remember correctly, you can search under lighting and get information and/or a manual through a typical product search. But you have to go to Inconcert to download the module. Everything should be in one place, with easy direct links to everything that pertains to the product.
Thanks for asking.
Sheldon Samuels
IPS Resources LLC
May ?I Agree? for the rest of my life that once I Log In I also agree to the AMX License Agreement that is presented at the front door of the InConcert center? Cross my heart, hope to die, stick a needle in my eye.
Also, I think that Christie Digital has a pretty good site for finding anything about their products.
Danny
http://www.advantech.com lets you browse by category and then drill down to a specific product and from there you can jump to a download page for all the pertinent data and software related to the product.
Bottom line for me is more emphasis on browsing vs. keyword or model # search. Aside from being able to browse Tech Notes as Dave noted, I?d also like to browse Netlinx modules (and soon Duet Jar files) and not be limited to just the 30 most recent. It would be great if we could page through them.
It?s probably too late in the game but it would be helpful if the pdf file names were something more than just a number.
Thanks for inviting our opinions.
Joe
As far as the Tech Notes on the AMX site, I inquired a few years back (before forums and the new website) if there could be a downloadable database, or at least a zip file with every tech note in it. It could be updated like the IR libraries (or not!) every 3 months or so. The workaround I have discovered is if you put 'TN' (no quotes) in the search box, it will give you all of the tech notes on the site (because every tech note starts with TN).
Joe
Thank you all for your input thus far, and please keep it coming!
It appears that you need two ways of searching - one if you know the model number you need, and one if you do not. If you do not remember the modeol number, the current Product Finder helps narrow down your product search by clicking through the category menu located in the left box. It sounds, however, as if this "category search" is not being used. Is it the categories, the interface, both, or something else?
Thanks again for your help!
I think multiple search options are required. I can think of the following:
1) By model number (eg. NXC-COM2)
2) By part number (eg. FG2022)
3) By type of device (eg. Netlinx RS-232 card)
4) By device function (eg. data communication)
5) By generic tree structure (eg. Netlinx - Controllers - Control Cards - Data - NXC-COM2)
At least as important is what is presented when the device is found: Each and every related mounting option, power supply, cutsheet, technical document, programming tool, module, code sample, firmware, related tech note, firmware history, etc. should be there.
Perhaps an 'I agree' should be agreed to when a person joins the AMX 'dealers, users' before they are given any access. (This would also lower any possible damage to ones eyes)
Joking aside and back on topic, I think the new product pages are WAY better than before. I particularly like the rotating 360 degree images for some of the products along with the filter and search options.
It?s good to see some of the suggestions posted here were taken into consideration and implemented. Nicely played AMX.<wiping brown stuff off nose>
