NS3 compiler error clue
Okay,
NS3 has been KILLING me with all the complier errors and file problems it's been having. However, I think I've discovered a behavior that might help the folks at AMX sussing out this problem. I've found that when I haver a compiler error I can get a good compile by doing the following (most times , but not all)
I quit NS3, go into the folder with the project and delete the project_name_here.src , .tkn and .tko files NS3 creates. Then reopen the project and hit build system and get one good compile. As long as I don't make any changes I can hit compile again with success. If I make any changes, it blows up again and I have to redo the above process.
    I never get compiler errors, but I also never build an entire project. I individually click the "Compile as NetLinx" button for every module, then the main program. It's gotten to be such an ingrained habit that I forgot the "Build Project" option even existed.
    DHawthorne wrote: »
    Ditto. The only time I actully used "Build Project" was to see what it did. I found it was a waste of time. It's quicker and easier to do as Dave does and just save includes that have changed, re-compile modules that have change and then compile the main.
  • jjamesjjames Posts: 2,908
    I ran into all sorts of problems of dependency with build project in the past that I just remove that button all together and just use compile netlinx.
  • Personally i had some problems with the Netlinx compiler and the Comodo Internet Security suite. When the
    Defence+ was activated the compiler was never finishing compilation and some times it was not even producing the compiled files (.tkn .src etc). Deactivating the Defence+ feature everything is working well.
    About the "Build project" command. I only use it when i have many modules in a project and do not remember which
    ones have been compiled with the latest changes i made. The only thing that i have to keep in mind is that the "Build
    Project" works only in the ACTIVE SYSTEM of NXS. If i try to Build another system the compiler looses the paths of
    the included files...
  • Jorde_VJorde_V Posts: 393
    I've had these exact same issues Eric, but never figured out why. And like you removed those files. Then it started happening again so I remade the workspace file and it stopped doing it. Maybe you can try that out, if that doesn't work pack it as an axw and go from there.
