Home AMX Technical Discussion
Advanced Digital Broadcast‏
I Have an ADB device and I want to control it via IR port of the NI-3100 but I didn't found it in the database of the AMX and I don't know where to search for the IR command for the device.
Anyone know how I can find the IR file???
    udi wrote: »
    First, check teh AMX website under the tech section and 'search for third party devices.' it might be there.
    If not, then it sounds like one you're going to have to capture yourself. If you do not have the AMX IRIS to capture it, you might post here and make arrangements for someone on the forum to capture the remote for you.
    Or maybe someone on the forum has already captured it and will share.
    Those are your options.
