Why does TO not work on this code?
DEFINE_DEVICE
dvTPMB_TV = 10001:7:0 //MBed TP Plasma Vol functions
TV_MBED = 5001:14:0 //Physical IR port for the plasma
BUTTON_EVENT[dvTPMB_TV,0] //Typically Volume Controls
PUSH:
TO[TV_MBED,BUTTON.INPUT.CHANNEL]
When this code executes, the IR is pulsed instead of continuously sent while I hold down the button.If I change the code to a stacked button event:
BUTTON_EVENT[dvTPMB_TV,24] //vol up
BUTTON_EVENT[dvTPMB_TV,25] //vol dn
PUSH:
It works fine. Is it something to do with the wildcard? 0
I use BIC w/ the "0" catch all when ever I use the "0" so I can say with certainty that BIC isn't the culprit. There used to be issues with "0" and holds that seems to have been resolved so I'm thinking it must be how the "TO" is handled by the system that makes a difference when using "0".
In TPD4 is the panel button set up as momemtary? If so that could be the problem.
You might just do the "TO" yourself in code by issuing an ON[TP,BIC] in the push and OFF[TP,BIC] in the release. Basically this is all a "TO" is, turning some type of channel on until it's released.
push: { if (button.input.channel) { // handle the button press } }when I use the [dv_TP,0] button press. I can't remember exactly why I started doing it, but obviously I must have gotten inadvertent button presses with b.i.c=0.// define_constant integer nIRchannelLimit = 170 integer nIRpresetLimit = 210 define_function integer isValid (integer startPoint, integer value, integer endPoint) { if ((value >= startPoint) && (value <= endPoint)) return 1 else return 0 } define_event button_event[dvIR_TParray,0] { push: { // TP and source tracking omitted here select { active (isValid(1,button.input.channel,nIRchannelLimit)): { // do source IR commands here } active (isValid(nIRchannelLimit,button.input.channel,nIRpresetLimit)): { // do source Preset commands here } active (1): { fnMainDebug('sourceControl',__line__,"'invalid IR channel: tp[',dpstoa(button.input.device),'] chan[',itoa(button.input.channel),']'") } } } }
