why does the Touch panal MVP-8400I not work on this code?
This code I got from amx site "widget". I tried with two touch panels, MVP 8400i and NXD 1000vi. But MVP- 8400i doesn't work. why?
DEFINE_DEVICE
dvTP = 10050:1:0
DEFINE_EVENT
DATA_EVENT[NotesPNLS]
STRING:
IF(FIND_STRING(DATA.TEXT,'KEYB-',1))
REMOVE_STRING(DATA.TEXT,'KEYB-',1)
IF(LENGTH_STRING(DATA.TEXT))
IF(FIND_STRING(DATA.TEXT,'ABORT',1))
ELSE
SEND_COMMAND NotesPNLS,"'^TXT-101,0,',DATA.TEXT"
ON[NotesPNLS,4]//turn on new msg indicator
BUTTON_EVENT[NotesPNLS,3]//ERASE
PUSH:
SEND_COMMAND NotesPNLS,"'^TXT-101,0, '"
OFF[NotesPNLS,4]//turn off new msg indicator
    You'll need to post more of your code. What you posted doesn't contain enough info to help you. For example, what is in the dev array NotesPNLS ? Also, you don't identify which element of the dev array created the data_event>string: in the code posted. Is there only one device in the array?
