IPAD connection problem.
udiudi Posts: 107
I have an AP of netgeer WG302 and when I am running the tpconrol on the Ipad sometimes he show me not connected for few secons
Whan can be the problem? Is it because it a netgeer AP ?
  • Jorde_VJorde_V Posts: 393
    udi wrote: »
    It could be the netgear, some have shown issues while running on WPA2, you can try setting it to WPA to see if that resolves it.
  • udiudi Posts: 107
    I am using WEP 64
    Try using WPA/WPA2 to see if that resolves it. Not sure about iPad + WEP64 + Network + Controller. Problem is most likely in your WAP though. Have you checked if you have the latest firmware running on it?
  • udiudi Posts: 107
    thanks I resolves the problem I raise the range from 54mbps to 300mbps
