Home AMX Technical Discussion
iPCLinkWeb or computer connection Solution
Hi all ACE,
to the point, how to send "F1~F12" from virtual keyboard or command from iPCLinkWeb to the computer with LAN ?
or maybe all of you guys have any solution and way to communicate with computer specially sending key "F1~F~12"
thanks and regards
Novi Andriyansyah
Indonesian Programmer
  • aksyalaksyal Posts: 21
    please help me any solution for this case ???
  • AuserAuser Posts: 506
    When you install i!-PCLinkWeb a sample project is installed in C:\Program Files\AMX Control Disc\Solutions\i!-PCLinkWeb.
    Have a look at the string output of the F1 - F12 keys on the keyboard on the sample touch panel and follow the code through from line 613 in i!-PCLinkWeb2Mod.axs to see how to do this.
    A cursory glance seems to show that
    send_command <PCLink Device>, 'SENDKEYS-F<function key number>'
    should do what you're after.
    eg. For F1:
    send_command <PCLink Device>, 'SENDKEYS-F1'
    Auser wrote: »
    eg. For F1:
    it's very kind of you...
    thanks and regard for your information
