TIMELINE_EVENT[0]
Greetings,
TIMELINE_EVENT[0]
nTimelineNumber=TIMELINE.ID
The above doesn't seem to work. Has anyone wildcarded a timeline event successfully?Thanks.
There's been a long time wish for such a thing as well as a timeline array
TIMELINE_EVENT[my_timelines]
A timeline stack does work, however
TIMELINE_EVENT[timeline_1]
TIMELINE_EVENT[timeline_2]
TIMELINE_EVENT[timeline_3]
TIMELINE_EVENT[timeline_4]
You can follow that stack up with the timeline.ID parameter to figure out which timeline tripped the event too.
Here is one way I have used a stack of timelines:
timeline_event[tlVolUP[1]] timeline_event[tlVolUP[2]] timeline_event[tlVolUP[3]] timeline_event[tlVolUP[4]] timeline_event[tlVolUP[5]] timeline_event[tlVolUP[6]] timeline_event[tlVolUP[7]] timeline_event[tlVolUP[8]] timeline_event[tlVolUP[9]] timeline_event[tlVolUP[10]] timeline_event[tlVolUP[11]] timeline_event[tlVolUP[12]] { stack_var integer index stack_var integer nOutput // tlVolUP is an array of timeline id #s for (index = 1; index <= length_array(tlVolUP); index){ if (timeline.id == tlVolUp[index]) { break } } nOutput = metAudioOutputMap[index] if (audSwitcher[nOutput].input) { if (audioAdjustVolume(nOutput, 2)) { send_level metreauKeypads[index], 1, ((audSwitcher[nOutput].volume * 2) + 35) } } }Thanks guys. This is how I have been doing it. I thought the [0] would be a better way. I think I posted the same question a few years ago and got the same answer. Thanks again!
What's the point of the for loop? Wouldn't this work just as well?
timeline_event[tlVolUP[1]] timeline_event[tlVolUP[2]] timeline_event[tlVolUP[3]] timeline_event[tlVolUP[4]] timeline_event[tlVolUP[5]] timeline_event[tlVolUP[6]] timeline_event[tlVolUP[7]] timeline_event[tlVolUP[8]] timeline_event[tlVolUP[9]] timeline_event[tlVolUP[10]] timeline_event[tlVolUP[11]] timeline_event[tlVolUP[12]] { stack_var integer index stack_var integer nOutput nOutput = metAudioOutputMap[timeline.id] if (audSwitcher[nOutput].input) { if (audioAdjustVolume(nOutput, 2)) { send_level metreauKeypads[timeline.id], 1, ((audSwitcher[nOutput].volume * 2) + 35) } } }This was from a piece of code that I originally wrote without the idea of stacking timelines, so I didn't setup the timeline IDs to be an easy sequence for that to work, so the for loop was the quickest way to do it.
In that case I would create a map similar to the one you are using for the outputs to avoid a for loop in a timeline.
