TPI/4 No Audio
I recently swapped out a TPI/3 for a TPI/4. It is Firmware Version 2.46.64. Setup went OK with the only exception being I do not have any audio on the panel for button presses or button misses. Is it a Firmware issue or a ELO Touch Driver issue?
Does anyone have the Firmware update file?
Any suggestions.
    As I recall, the audio comes out of the TPI, not the monitor.
  • dchristodchristo Posts: 177
    The TPI/4 does not have on-board audio. You'll need to connect the audio output of the TPI/4 to your touch monitor or to external speakers.
    --D
    Yeah, I didn't really phrase that well. The TPI is the source of the audio, so there are no drivers, etc., for the Elo to use (as far as the audio is concerned). It is just acting like a set of speakers as far as the TPI is concerned.
