Coolmaster
Has anybody had much experience integrating a DAIKIN VRV system using the Coolmaster 1000D? Basically, the system was up and running fine (without programming, but the Coolmaster was picking up the units), but suddenly the coolmaster is not picking up any of the units, and I was wondering whether it's an issue from the DAIKIN or Coolmaster side. All of the A/C units also report an error (error U4 if I recall correctly, which is "U4 System Transmission between indoor units")
Any ideas?
Any ideas?
First one worked fine, but the second one gave us all kinds of problems. Sometimes it would pick up the units and run fine for a day or two - then it would just lose everything.
After eliminating things like power supply and RS-232 cable we just sent it back for a replacement. The one we got back has worked ever since.
EDIT: Should also say that I don't think Daikin endorse the Coolmaster products in any way - in fact they may even invlidate warrantees etc if they find out. They certainly won't help you with it! This was the case 2 or 3 years back - not sure about now. If you're seeing errors on the units I'd unplug the Coolmaster and get those resolved with Daikin and / or your HVAC installer first. Then try to use your Coolmaster again.
Thanks! Managed to resolve the problem, and outdoor unit was not connected to the system. Luckily Daikin has no issue with the system, at least not thus far. A couple of further questions for you:
1. With the serial pin-out, is it 2-3 and 3-2 or straight through?
2. SEND_STRING device, 'allon' ?
Thanks in advance if you can answer the above, much appreciated!
As for the control, remember to add a CR :
SEND_STRING device, "'allon', $0d"
Good luck!
Sweet, of course! $0A should also work according to the documentation.
Serial cables: bane of my life!
Here is code sample :
Hope this help ?
