NI-3000 Program Port Dead ( Any Solution)
in AMX Hardware
Hi all,
I have a NI-3100 and the Program port seem's to be death. Unable to access to the processor. is there a way to communication with the processor by another way.
Is there a way to use another com port for programming, i have search on the Technote and on the forum, the only things i found it's about the axcess processor with the command Esc MC or Esc MD.
thanks for your help.
If it's a working system, you might be able to find the ip address of the master by looking at the setup of a modero touch panel. it'll have the master's URL.
It would be nice if i could set another port has a programming port
can i use another device connected thru Axlink to communicate with the master processor ?
Unfortunately you cannot use the other ports for a program port. Also, there's no way to use the AxLink buss either. It may be bricked and you'll have to send it in to be reset.
Hi
I've got similar problem resolved. Connected AMX NI3100 with Ethernet cable to PC (directly) and started Wireshark application (free sniffer) which discovered AMX's IP address (even from different subnet). Then I set my PC to the same subnet IP address, and was able to access NI3100 via NetLinx Studio...that's it.
