Home AMX Technical Discussion
Barco DP2K-P
Has anyone controlled a Barco DP2K-P? Have you got the command strings for that particular model, or is it just the same as the other Barcos? I haven't touched a Barco yet.
  • I have not coded for that particular projector, however I have just coded for several other DP2K models (the c12 is the latest) and the control codes are them same as barco has been using for their series one cinema grade projectors. The only difference as far as I can tell is the port number for IP control, it is different based on the series of projector you've got.
