IP addressing
Hi to all, I have a Ni-3100, WAP250 and MVP-5150 TP how do I set the IP Address of each device? I have the installation manual but quite confusing. thanks and regards to all.
    The NI-3100 is set by either using the Network Addresses option under diagnostics in NS, or the standalone NetLinx Diagnostics program.
    The WAP250 has a web page interface for its settings; I believe it has a default address you can use for the initial setup. If not, or if you just can't find it, you'll have to search for it with something like AngryIP Scanner. It may show up in Bonjour, but I'm not certain of that.
    The touch panel network address is in the Protected Setup section.
  • kenwood329kenwood329 Posts: 18
    Thank you very much haven't done an AMX installation for 2 yrs until recently we got a project which requires 7 NI-3100 for the 7 conference rooms, just can not remember the last time how I interconnected the setup, I was looking for my notes but coudn't find it, anyway I'll try my best to set it up, Thank you very much Sir.
