Axcent3 in slave mode
banobano Posts: 175
I'm integrating a used Axcent3 I purchased from ebay into a Netlinx system. Before I switched it over to slave mode I noticed in Open Axcess that IR ports 1 and 6 were configured for serial mode. Despite the fact that I declared both ports 1 and 6 for IR mode in an online data event, I cannot download IR files into the ports in question. Any thoughts?
    This is from my poor addled memory - but try sending a ZAP! command to each IR port. (or it might be !ZAP) That'll clear it out of all settings.
  • banobano Posts: 175
    ZAP!
    ericmedley wrote: »
    Under software history, that command is not listed for Axcent3, but is in AXB-IRS4, so I'll give it a try anyway. Thanks for the quick reply!
    Examples:
    SEND_COMMAND Dev,'ZAP!' Clears Dev IR load and sets CTON
    and CTOF to 5.
    SEND_COMMAND Dev,'ZAPALL!' Clears ALL 4 devices IR load and
    sets CTON and CTOF to 5.
    bano wrote: »
    Examples:
    and CTOF to 5.
    the commands for setting the IR ports will be there as well. Hope you get it going. e
    !ZAP
    ericmedley wrote: »
    It worked! Went in through the Netlinx master via telnet and Zapped them puppies, and now they work. Thanks Eric!
    bano wrote: »
    ... another happy ending! glad it worked. e
