programming support
I have a video wall for that i have created 10 buttons on TPD (10 modes like case1, case2........ case10 by using switch case) each one performs particular task,now i want to create 'up/down' buttons ,if i press UP mode will change in ascending order,if i press down mode will change in descending order,please tell how to do the program in NetLinx.
    You'll need to post some code. There are several ways to do it but will depend upon your code.
    Also, this forum is not a place to come and have others write your programs for you. We love to help but it's more along the idea of advice, not doing the actual work.
  • the8thstthe8thst Posts: 470
    Make the buttons increment/decrement a variable and then run that variable through the same switch..case section.
    It will be cleaner to turn the switch..case into a function so you are not duplicating code and both your up/down and discrete buttons will have access to it.
    Oh.... and what Eric said.
