Problems with MAX MMS-HT-12
in MAX by AMX
I have a problem
The AMX MMS-HT-12 was hanging after 15 minute of playing a movie. We did a hard reboot and it asked for maintenance root and password.After a few minutes of booting the error occured stating Boot Device could not be found.
Now it is stuck.
Now it is stuck.
Your best bet is to call tech support to get a solution to your problem.
I would check the PS before sending the unit for service. I saw the same error about the O/S at one point when the disk drives weren't powering up properly.
--John
But what can you do? First, check if all the drives are online (no red lights). Maybe you'll get lucky, and reseating the boot drive will bring it back. Otherwise, if you can get a boot disc with the OS, you may get it running again by restoring it. However, I can't speak to whether the media will survive.
