Home AMXForums Archive Threads AMX Hardware Inspired Signage - Digital Signage
IS-SPX-1000 firmware upgrade to v2.2.1
Has anyone else noticed that after upgrading the IS-SPX-1000 firmware to v2.2.1 that project text all becomes offset downwards ?
Didn't really want to upgrade to v2.2.1 however upgrading to v2.1.2 doesn't appear as an option on the web update.
Not sure if this means XPress v2.2.1 is about to be made available or not, which might fix this along with the JavaScript issue.
  • Dave_UKDave_UK Posts: 54
    Dave_UK wrote: »
    XPress v2.2.1 has just been made available on the AMX site.
  • Dave_UK wrote: »
    Text area layout has been modified in version 2.2 to be compliant with the SVG specification, and to improve the compatibility with other SVG-compatible software (such as Opera). The position of the baseline of the first line is now equal to the line-increment. This causes text to appear lower in a frame than in version 2.1.
    Side effect:
    fit_text template from version 2.1 of HMD might not display the text anymore due to a rounding error. The solution is either to use the new fit_text template, or to edit the template to increase the vertical margin by 20%.
    quote from Spinetix.
