Zigbee gateway device number – static or dynamic?
in AMX Hardware
When configuring the Netinx Settings for a Zigbee gateway should we accept the dynamic device number (the 32000 range) that is assigned to the gateway when it connects to a Netlinx master via the system number or should we assign a static device number? Both seem to work.
If we should set the device number where should we start? The standard device number for the first TP is 10001. Is there a standard device number for the first gateway?
I think you don't want to leave it up there. I use 501:01:0 and go from there myself.
I start the R4s at 11001.
Sent from my MB860 using Tapatalk
It makes it easy to quickly tell which R4 is connected to which gateway and to easily tell if gateways are offline.
