VioP to AXB-DTMF+
in AMX Hardware
I have an AXB-DTMF+ that I use for caller ID and to make outgoing calls through a Panasonic PBX and a standard POTS line. It’s been working great for years until this week when AT&T switched me over to VoiP when I converted from Comcast to U-verse.
Now that I have VoiP I can still make outgoing calls through the AXB-DTMF+ but my caller ID no longer works. I get signaled that the phone is ringing but nothing after that.
Do I need something like this VioP Analog adapter to make my caller ID work again?
http://www.amazon.com/Voip-2-PORT-Fxs-Analog-Adapter/dp/B001TZZ38O
Trying to find somebody at the phone company that understands how phones work has been futile and frustrating and I don’t know enough about it. With the vast array of intelligent folks on the forum I’m hoping somebody here can help me out.
The number used to come in as aaa-bbb-cccc when I had a POTS (plain old telephone service) line.
Now it comes in as 1aaabbbcccc with U-Verse via VoiP.
I’ve got no problems from that end since I just need to parse it differently.
I can use the AXB-DTMF+ to make outgoing calls without issue but I can’t get the caller ID info to make it through to me. The channel event for RING does get triggered.
When I monitor the strings of the data event for the DTMF every once in a blue moon I get the CLID- feedback but only if I use line 2 in my house to call line 1 (which is where the AXB-DTMF+ is tied to.) I have never seen any CLID- feedback for any calls that are generated from the outside of my house.
I’m wondering if the caller ID comes in too fast for the DTMF box. When I had a POTS line the caller ID came in between the first and second rings. Now with U-Verse the caller ID shows up on the TV a split second BEFORE I even hear the FIRST ring. Maybe that’s messing with the AMX box, I don’t know.
I’ve read that other people have complained about the same thing that once they switched over to U-Verse (a.k.a. U-Suck) the equipment they used for caller ID that worked with a POTS line is broken with U-Verse VoiP. This shouldn’t be rocket science. Caller ID has been around for decades.
I really miss my caller ID. I had a great setup. When a call came in I did a lookup in a flat file database to see if it’s a number I recognize and then get the friendly name for it. For example my cell and my wife’s cell along with my two sons all come in as Joe Hebert since we share the same plan. Instead of showing my name for everyone I can look up the number then display Joe’s Cell or Linda’s Cell or Jimmy’s Cell, etc. as a popup on the TPs in the house along with displaying the name on my BetaBrite. The TPs have a call log and a phone book where I can do one button dialing via the DTMF box.
I’m getting nowhere with AT&T tech support. Since caller ID is on the network now I would think I should be able to write my own code to trap it but I’m not having any luck finding out how to do it.
I want my caller ID back....
Your note that the CLID is coming through when calling from line 2 to 1 on the same system tells me that the CLID is operational when inside the voip system, but not being sent through from the POTS carriers to the voip carrier. I don't have a second line at home to test with but your symptoms do point that way.
Have you tried to see if there is any CLID coming through on the voip line by using a standard calling number display unit on the voip line?
The CLID shows up on a V-Tek cordless (about $25) every time. Go figure...
I tried what you suggested and I let the phone ring until the answering machine picked up on the 5th ring and the AMX box didn’t report any CLID feedback. I then disconnected the answering machine and let the phone ring 10 times and I still didn’t get any CLID feedback.
I need to find a new piece of hardware that plays nice with VoIP. Either that or I tell AT&T that I want my POTS back. This shouldn’t need to be so complicated.
I thought the AMX DTMF box was discontinued or at the very least limited, however, the web site shows they’re still readily available. I wonder how many of these are in the field. I’ll report the issue to AMX and see what happens. I’m sure AMX has bigger fish to fry than the DTMF box but it’s worth a shot.
I don't think the CID issue is your DTMF card's problem, though, since your Panasonic phones also have trouble getting the info -- as well as plenty of other hardware (so says the internet). Obviously the RG (Residential Gateway) it is getting the CID info since you see it on your TV (via IP). I don't think the AT&T RG is generating the analog side of things properly.
As a side note, I had a terrible time with the WAP built into the RG (I still have the "Residential Gateway" even though I don't have U-verse TV or U-verse Voice, all I have is the fast U-verse Internet). I ended up disabling the built in router/WAP and use an external router/WAP.
