Home AMX Technical Discussion
Hi, need to swtich on/off audio to 2 different zones.
Hello, I need to be able to switch on/off 2 zones of 100vline audio. is there a device that will enable me to do this which can be controlled with an NI2100.
    If you are feeding the 100v amp with line level, you could route the line level signal through an Autopatch Precis 8x8 and get zone control. Each zone would need a separate audio feed tho if you want to control them independently.
  • julianjulian Posts: 13
    I have one feed to the amp so i need to switch in the speakers as required.
  • WazzaWazza Posts: 8
    I usually just make an external relay box and drive that from switching 12v through the AMX relays. I wouldn't feed the 100v speaker lines straight into the NI as depending on the wattage used, it can blow the relays (found this out the hard way).
    Wazza
