Mimic contact closure with Moxa N-Port 5410?
Anyone know if I can do this by specifically calling flow control lines to low/off?
thanks,
  • dnahmandnahman Posts: 32
    Possibly --
    You should be able to change the flow control lines via the command port. I looked at the Moxa site, but other than the windows library I didn't see any documentation on the protocol itself. Did you find documentation, or were you planning on wiresharking it?
    Electrically, the flow control line will be flipping between a negative and positive control voltage, so it isn't exactly a contact closure -- you'd need to buffer that out with a transistor or a relay.
    HTH,
    David
  • I've been having trouble getting the API out of Moxa. They just keep referring me to the OS applications. They do claim that the library is embedded in those programs, and I can reference them that way. I haven't looked yet.
    Because... at this point, I've more or less discarded my idea of trying to do this. I've swapped out a 'contact closure only' device for one with a crude RS-232 (rx only) interface, and that works OK.
    Thanks!
