iRidium windows client settings
Hi
Someone succeeded to make the windows client part of iRidium work ?
Convert TP4 to the iRidium .exe is easy.
But where can you set the IP address of the master and the device nr of the TP client ?
I would like to offer it as a spare or temporary TP in case the AMX TP would fail.
And in some cases as an admin interface.
Thanks a lot in advance !
Grtz
Mike
PS: tpcontrol on iPad2 works as a charm !! ... but in B2B market we prefer to implement AMX TP's
    Mike, you set the parameters within transfer before you build the .exe, both device number, master IP etc
    Right click the tp4 file in designs and select device configure to set the parameters.
    Works like a charm
    Also if using client in windows7 run iridium.exe as admin!!
  • MikeXMikeX Posts: 5
    Works ... Tx !!!
