TPI-PRO-DVI and ELO Touch (APR)
thomas.jud
in AMX Hardware
Does any body know if a TPI-PRO-DVI works with a EloTouch Monitor 1519L (with Acoustic Pulse Recognition (APR) technology)
This monitor has got just a USB connector.
I tryed all possible Touch Input Drivers.
Firmware TPI: v2.6.36
Driver TPI: v2.5.9
or can AMX load driverupdate ?
Thanks for help.
Tom
Driver TPI: v2.5.9
Thanks for help.
Tom
IIRC you actually generally don't want to select a driver for a USB touch monitor. The first time I used a USB touch monitor (it was a Planar monitor) I made the mistake of trying to select a driver and had to call tech support to figure out where I went wrong. I think you have to power cycle the TPIPro to get a USB monitor to work if you've selected a driver.
I'd say you should get in touch with tech support.
One and only solution:
Order a new ELO Touch with Intellitouch overlay
Cheers
Thomas
