Solar Water Heater - Circulation Systems
roognation
A client is asking for a unified solar water heater system/controller that I can interface to and control/retrieve data from. I am capable of installing
1...a recirculation pump/contactor
2...few in-line water thermocouples
3...a couple of pressure sensors
But I was hoping there would be something more integrated out there that I could just buy off-the-shelf and talk to via serial /Ethernet.
Anyone tried Calefi? http://www.caleffi.us/caleffi/en_US/Site/Products/Catalogue/args/sezione/Family270_Differential_regulator_thermostats_SOLAR/path/2~257~257_260-details/include/~applications~catalog~serie.jsp/posizione/prodotto/index.sdo
Or Heliodyne? www.heliodyne.com
Any recommendations?
Thanks!
Thanks!
Slight bump... Perhaps Modbus options? Anyone?
You'll need to shop around for a pressure sensor that's 232/485 and connect this directly to AMX but using HAI would be an inexpensive way to get multiple water sensor that you could strap on the pipes or use submersion wells like they typically use on boilers for return manifold temp, hi limit.
Oh, yeah, thanks! That Resol unit looks like a great unit:
http://www.resol.de/index/produktdetail/kategorie/1/id/9/sprache/en
The 24VDC-powered version can be found here:
http://www.resol.de/Produktdokumente/48002570_DeltaSol_M_24V.monen.pdf
From what I found out, the retail price is around $ 700.00. Your mileage may vary. The units are sold in the USA by http://alphathermalsystems.com/
Still looking for a protocol guide.
Thanks!
