Defaults for variable declarations
I'm suddenly running into problems where I run out of non volatile memory and my variables and arrays wont show any value in debug.
I have been able to correct the issue by going back and explicitly declaring all variables as VOLATILE ( I know I should have been doing this already.)
Did the defaults change in Studio 3 or something? I never bothered with this before and never had a problem?
  • mpullinmpullin Posts: 949
    Nope, it's always been like that.
  • PhreaKPhreaK Posts: 966
    Have you / code that you have loaded changed you're duet memory allocation? This comes out of the same memory (I think).
    Given the fact that the majority of variables should be declared as volatile and very few variables need to be non-volatile I wonder why the default is the reverse of what it should be.
    The thing to really watch is modules. It's easy to miss default declarations in them, and if you are running more than one instance, the problem multiplies.
    I've never put anything but volatiles in a module. I didn't think you could put nonvolatiles and/or persistent cars in a module???
    ericmedley wrote: »
    You can't put persistents in a module, but like anything else, if you don't specify volatile when you declare a variable in DEFINE_VARIABLE in a module, it defaults to non-volatile. If it's one of those modules that you need to make an instance for every UI device, you can run out of non-volatile memory real fast ... it's especially a problem dealing with someone else's module, as it's far more likely to slip past you.
    DHawthorne wrote: »
    Yeah, any time I've needed to use a persistent variable in a module, I just read/write the value(s) to a file.
    ericmedley wrote: »
    or create a persistent var outside the module and pass it in as a parameter. If using multiple instances I'll create a persistent array and pass in the index of the persistant var that matches the instance of the module. Basically cuz sometimes I'm too lazy to read & write.
