Yamaha RX-A2010 receiver
Does anyone have the protocol for the Yamaha RX-A2010 receiver?
  • Hi Joe,
    I have worked with 3 or 4 different protocols for Yamaha equipments.
    So, start by trying out the attached codes. If they do not work, i'll come back with other protocol :)
    Kostas
    Thanks Kostas. I’ll give it a try when I get a unit here.
    I’m an Integra man myself. Their protocol stays consistent from model to model, unlike Yamaha.
    Hmm...
    I can’t extract anything from the zip.
    Every file gives me the same error: this file is not in the standard Zip 2.0 format.
    For example:
    skipping: text\YNCA_Command_List_RX-V1067_R.txt this file is not in the standard Zip 2.0 format.
    I tried downloading twice but the unzip gives me the same errors.
  • Joe,
    i am using 7-Zip for my compression/decompression needs and when i tried to attach the files in a .7z format, the forum didn't let me. So i compressed them using .zip file format BUT with PPMd compression... maybe that is my mistake.
    No problem though... here i am again with new .zip files for you :)
    Kostas
    Yup, those unzip.
    Thanks again Kostas.
    I got a hold of the correct docs and they're attached if anyone else needs them.
