Home AMX Technical Discussion
Control Samsung UC6300 LED backlight LCD screen with RS232
We recently moved from using projectors to LCD screens, and the screen of choice was the UC6300, which has a 3.5mm "REMOTE" control input.
Upon using the "easter egg" menu, which I can go in and change the remote control from UART, logic and diagnostic, I left it on the default UART, which I know is not normal serial 232C, however I didnt think logic was the correct item.
After this, I wired a 9pin to 3.5mm cable using the attached diagram.
Attached is some code that doesnt seem to do ANYTHING..
dvTV		= 5001:6:0	// Samsung LCD 55" -- 9600,8,N,1
VOLATILE INTEGER nTvChannels[] =
    526,	// 0
    527, 	// 1
    528,	// 2
    529,	// 3
    530,	// 4
    531,	// 5
    532,	// 6
    533,	// 7
    534,	// 8
    535	// 9
// TV's
DATA_EVENT[dvTV]
    ONLINE:
	WAIT 5
	    SEND_COMMAND dvTV, "'SET BAND 9600,8,N,1 485 DISABLE'"
// LED TV's
BUTTON_EVENT[TPS,520]	// TV 1,2,3 Power Toggle
    PUSH:
	WAIT 9
	    SEND_STRING dvTV, "'P'" //
BUTTON_EVENT[TPS,521]	// TV 1,2,3 Source Change Toggle
    PUSH:
	WAIT 2
	    SEND_STRING dvTV, "0,'N',1" //
BUTTON_EVENT[TPS,522]	// TV 1,2,3 Channel up
    PUSH:
	WAIT 2
	    SEND_STRING dvTV, "'u'" //
BUTTON_EVENT[TPS,523]	// TV 1,2,3 Channel down
    PUSH:
	WAIT 2
	    SEND_STRING dvTV, "'d'" //
BUTTON_EVENT[TPS,524]	// TV 1,2,3 Volume up
    PUSH:
	WAIT 1
	    SEND_STRING dvTV, "'r'" //
BUTTON_EVENT[TPS,525]	// TV 1,2,3 Volume down
    PUSH:
	WAIT 1
	    SEND_STRING dvTV, "'l'" //
BUTTON_EVENT[TPS,nTvChannels]	// TV 1,2,3 Number keys
    PUSH:
	SWITCH( GET_LAST( nTvChannels ))
	    CASE 1:
		WAIT 1
		    SEND_STRING dvTV, "'0'" //
	    CASE 2:
		WAIT 1
		    SEND_STRING dvTV, "'1'" //
	    CASE 3:
		WAIT 1
		    SEND_STRING dvTV, "'2'" //
	    CASE 4:
		WAIT 1
		    SEND_STRING dvTV, "'3'" //
	    CASE 5:
		WAIT 1
		    SEND_STRING dvTV, "'4'" //
	    CASE 6:
		WAIT 1
		    SEND_STRING dvTV, "'5'" //
	    CASE 7:
		WAIT 1
		    SEND_STRING dvTV, "'6'" //
	    CASE 8:
		WAIT 1
		    SEND_STRING dvTV, "'7'" //
	    CASE 9:
		WAIT 1
		    SEND_STRING dvTV, "'8'" //
	    CASE 10:
		WAIT 1
		    SEND_STRING dvTV, "'9'" //
When I press a button, the TX Led lights, however no RX light.. but the cable was tested with a cable testing and it is all correct ~ the cable is about 45 feet long, is this too long for the AMX ?
Any help on this is much appreciated ! :)
-Paul
  • Samsung UC6300
    Change: SEND_COMMAND dvTV, "'SET BAND 9600,8,N,1 485 DISABLE'"
    To: SEND_COMMAND dvTV," 'SET BAUD 9600,8,N,1' "
    I don't know if you did a copy of your code, but BAND should be BAUD... and you don't need the 485 DISABLE part.
  • OHH. .thank you, I did miss that, that was copied directly out of netlinx; I'm suprised it compiled..
    Is there a reason when or when not to have the 'DISABLE 485' ?
    I have always used this just because it is how I saw others.
