Problem in connecting PC to master NI-900
Haven't program master for at least a week - it was powered off.
That time it had static ip in local network with only 2 devices - router & my laptop.
Yesterday tried to connect in Studio via Ethernet and received a reply - "Failed to connect".
RS232 for programming didn't work at all for a month already. Changing baud rate, pc didn't help - i assume something wrong
with condenser inside the box.
Master replies on ping, but telnet won't connect.
Port scanner says that 21 (ftp) is opened, but still after trying to connect - it shows login/pass board & default pass (NetLinx, administrator and etc.) Telnet on port 21 shows - "220 VxWorks (VxWorks 6.3) FTP server ready"
didn't work.
Firewall is off.
Please advice me something. Can't check the code w/o master!
  • Problem solved.
    Strange, but reserved dip switches number 2,3,4 must be off (down) position.
  • sam.yoonsam.yoon Posts: 6
    wrong port
    didn't work.
    Firewall is off.
    As you probably have figured out by now, telnet port is 23.
    21 is FTP port.
