Connectors for Netlinx Controllers
                                  in AMX Hardware
                    Greetings,
Could someone please tell me the manufacturer and series for the smaller connectors used on Netlinx controllers. I need to replace some missing ones on an NI and an NXI.
Check out phenoix(?-I think the spelling is wrong but you know the bird that sets itself on fire every 500 years and is reborn from the ashes.) I usually get my connectors from my local electronics dealer.
The connectors are called mini-Phoenix connectors but I have yet to find an external supplier for them although perhaps someone else knows where they can be obtained outside of AMX. I order them from AMX since all of the connectors are sold seprately and have their own finished good numbers. For example, the 2-pin mini-Phoenix for PSN6.5 power supplies (also works for IR connections) has a part number of FG41-5025 and costs $2.10 (dealer) the last time I ordered. You can get the part numbers from your rep and order them from AMX if you can't find an alternative outside supplier like Thomas has found. We don't have any good electronics suppliers in our area and I have not found an online dealer that carries the parts.
Reese
I twisted some arms in purchasing to get me a dozen of each configuration, and two dozen of the two-pin connectors (for IR) to have as spares. I am also careful to collect and hang on to any leftovers. For example, I have lots of two-pin green connectors becasue all the masters come with one for the power, and the power supplies come with them as well. You can make up any configuration you like in a pinch with the two-pin plugs. Any time a controller gets trashed (very rare, but it happens), I scavenge the connectors. Sometimes I will scavenge unused connectors from an in-service controller, if I know for a fact they will never be needed, but more often I leave them, just in case.
Greetings,
Bob.
Phoenix Contact also has a similar part of which they are sending me a sample.
Almost all of the larger parts distributors sell them:
Allied
Newark
Mouser
and many others
They are made by Phoenix (the original) and WECO.
The older Axcent size is 5.08mm and the smaller size is 3.5mm
If you purchase them from the above vendors, they are about half the price of AMX.
If you need part numbers, let me know.
I want to buy some connectors for a NXI but I can't find the part number from WECO. Could you give me the part number, please?
Thanks very much,
Aldous
I don't have the WECO numbers, but I do have a list of Phoenix numbers you can get from Mouser Electronics.
Tom
Aldous
