How to convert HEX string to Float?
I have for example HEX String of float received from device
"4640E6B7"
and need to convert it to "12345.67871"
any ideas?
please help
    Is there always a certain number of decimal places? Do you have a portion of the control protocol that identifies what is being passed to you in HEX format? I am having some difficulty determining how the conversion can be performed without a little more information. If the first x characters are always before the decimal, and the last 8-x characters are after the decimal, it would be a lot easier.
  • HedbergHedberg Posts: 671
    z00f wrote: »
    "4640E6B7"
    any ideas?
    please help
    Ok. It looks to me like what you have is a 32 bit (single precision) binary representation of a floating point number. The way that a floating point number is represented as a binary number is defined by Ieee 754. Searching the forum for "binary to float" turns up two threads the first of which has some code which will convert a 32 bit (standard precision) binary representation into a floating point. It also includes a link which will lead you to:http://people.rit.edu/meseec/eecc250-winter99/IEEE-754hex32.html which will give you a very interesting result if you insert the hex string you entered:"4640E6B7"
    Anyway, doing that search in the forums will lead you to a bit of code which will probably solve your problem.
    Here's a link http://www.amxforums.com/showthread.php?3423-Ieee-754&highlight=binary+float to the thread with the code. It's in the second message, the one by jweather (thanks to him).
  • z00fz00f Posts: 4
    Thank you all for answer!!!!
    Problem solved! It is Ieee 754 and very beautiful library i found here: http://code.google.com/p/amx-netlinx-common/source/browse/trunk/math.axi
    and demo code:
    // b7 e6 40 46
    // 12345,67871
    stack_var float f_value;
    stack_var long l_value;
    f_value = math_build_float(hextoi('4640E6B7'));
    l_value = math_float_to_bits(f_value);
    send_string 0, "'VALUE(f_value): ',FORMAT('%5.5f',f_value),13,10";
    send_string 0, "'HEX VALUE(l_value): ',FORMAT('%X',l_value),13,10";
    It work very good!
    Thank all. Topic can be closed.
