MVPs, beautiful but...
I love the way the MVPs look, there are truly a work of art, except for one thing, the cheap plasticy shell.
Why not use a metallic material? Its not like these are bargain basement units.
________
BMW N62
  • yuriyuri Posts: 861
    An MVP isnt really a lightweight. And making the outer thing metallic instead of plastic :s i think it would way weigh a ton.
    The problem isn't that it's palstic - the old Viewpoints were plastic and have the durability of a tank (and clean up real nice too). They could completely redeem the very sub-par Modero Viewpoint cases by simply doing two things: (1) use a color that is molded into the plastic, not a veneer; (2) use a harder plastic. Just number one would go a very long way. These very nice panels look very bad after only short periods of use as the silver wears off and exposes the white plastic beneath.
  • RWozneyRWozney Posts: 19
    Yah, what he said.
    I have had a number of customers take note of the poorly aging finish on the MVPs. This is not an isolated problem although the problem has been much worse on a few MVPs that were shipped maybe 7 months ago and were replaced by AMX promptly. This is definitely something that needs to be addressed.
    RW
  • flcusatflcusat Posts: 309
    Does this problem still exist with the MVPs?
    Yes. AMX offers replacement cases for excessive wear; I have gotten quite few of them at no charge. No idea of their intended long-term fix, but a new case seems to be the interim solution.
    oh? i didnt know that... item number available?
    MA5965-84K Mech Assembly
    I keep a few around for spares; for a while my boss was ordering one with every new panel just so we could keep customer units "clean." They don't come with a new nav button cluster though, and those wear out the fastest :(.
    By the way what use do you give to the four button on the left of the MVP-8400? I'm assuming that the can't be engrave.
  • AvophileAvophile Posts: 70
    I typically do:
    volume up
    audio functions (pop-up an AVR function page)
    mute
    volume down
    Rather inelegant but it puts a related cluster of the three most commonly used buttons (and a throw-away) right where the channel surfer wants it.
    Each button pops up a small indicator saying what it is doing.
