Netlinx master firmware questions
tomfuke
in AMX Hardware
Hi,
It's been a while since I did any Netlinx programming, and I'm in the process of refreshing my knowledge of all things Netlinx. The first thing I want to do is upgrade my NI-3000 with the latest master firmware, but I have a couple of questions:
- Even though I am not planning to do anything with Duet just yet, would you still recommend that I install the "Duet Master Firmware" rather than non-Duet?
The only downloadable controller firmware for NI-3000 states that it "...requires master firmware 3.60.447 or later...", which implies that I need "Duet Master Firmware" (currently v3.60.453). The current non-Duet firmware for this master is v2.32.148...for which there appears to be no downloadable controller firmware.
Any advice gratefully received!
Tom
Tom
I have some NI-3000 in an old (since 2005) installation. I recently upgraded them from the "old" non Duet firmware to the latest Duet firmware. Although they did run low on memory (due to the requirements of the bigger firmware) they never stopped working.
I also do not use any Duet / non Duet modules in the source code. I performed the update for the reasons of stability, bug fix and new features.
Good luck with your "refresh" of the Netlinx Language
Kostas
Tom
You can reduce the memory impact of the newer firmware if you aren't using DUET for anything. Connect by TELNET and type the command
set duet mem
It will reply that it is currently set to the default, 8megabytes.
At the prompts, type 3 to set it to the minimum, 3 megabytes.
Press ENTER... it will confirm... you need to reboot to get back your 5 meg.
Note that this makes the NetLinx WEB SERVER quite slow... it uses duet!
If is for this reason that I always bump up the Duet allocation to at least 12Mb. I know others have memory-hungry programs which this becomes an issue on, but I've never got close to using all my 32Mb on NI-3000 masters. It can be frustrating when the web server doesn't serve up the security pages due to a minimal allocation of Duet memory.
Roger McLean
Swinburne University
I appreciate all of you making these comments/suggestions. Good stuff...
Tom
