I have a 3100 Central Ni and she just went out.
Good morning.
No LED lights up when I connect to the source, the source has changed and nothing.
Can you help?
Its something I do without for assistance?
Would not want to acquire and another, because here in Brazil are very expensive products and the customer is not in order to pay.
I have to resurrect it?
Endendo electronics, but not open it.
Att
    There are so many things that could be wrong that it's not possible to give you any help on the forum. Are you an AMX programmer? Are you an AMX dealer? Let's start with what your skill set is and what you're going to be able to do or not.
    Turn on dipswitch #1 on the back and power cycle it. If it turns on and the lights look normal, the program is locking up (dipswitch 1 disables the programming). If it still doesn't act right, you have little choice but to replace it or send it to AMX for service. If it seems normal after that, you have to go through the program and see if you can find what's going on.
