Odd Compiler Error_
DEFINE_VARIABLE
VOLATILE CHAR cTX_Queue[HVAC_ZONES * 128] ;
or
DEFINE_VARIABLE
VOLATILE CHAR cTX_Queue[HVAC_ZONES * 64] ;
results in this:
ERROR: file\path...... C10219: Array [CTX_QUEUE] must have an initializer if bounds are not specified
While the same thing with a number from 1-63 or 65-127 or 129-256 compiles just fine. I didn't actually try every number but everything I did try other than 64 or 128 did work.
HVAC_ZONES is an integer constant of 4.
  • I don't have it open and set up to test, but memory tells me that you aren't allowed to do variable or constant math inside a variable declaration. I think it does allow direct numeric math though.
    Edit: I re-read your post and now understand what you are saying... it was the number and not the constant that it didn't like. That's pretty weird!
    Looks like you found some sort of bug.
    You can change HVAC_ZONES and/or your multiplier to any numbers but if when you multiply the two and the result is a multiple of 256 the compiler chokes. If it's not a multiple of 256 the compiler is happy.
    Odd...
    vining wrote: »
    DEFINE_VARIABLE
    or
    DEFINE_VARIABLE
    results in this:
    Odd. As in, make HVAC_ZONES an odd number.
  • try this,
    DEFINE_VARIABLE
    VOLATILE CHAR cTX_Queue[(HVAC_ZONES * 128) + (256 - 256)] ;
    and it will compile.
    credits to AMX support Germany for this workaround.
    Did they have a theory behing that? In this instance it's easier to make the queue large or smaller since it does't really matter but let them play with this:
    DEFINE_CONSTANT //NUMBERS OF MIs, H48 AND RF LNIKS   <------------------------------------- CHANGE VALUES IN HERE!!!! FOR JOB ---------->
    //NUMBER OF PROCESSORS		///////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
    HWI_TOTAL_NUM_PROCs		= 1 ;   //TOTAL NUMBER OF PROCESSORS IN THE SYSTEM.
    //PROCESSOR NUMBERS & COUNT	///////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
    HWI_PROCESSOR_1			= 1 ;   //PROCESSOR 1 OR NUMBER OF PRCESSORS IN SYSTEM (MAX 3)
    HWI_PROCESSOR_2			= 2 ;   //PROCESSOR 2 OR NUMBER OF PRCESSORS IN SYSTEM (MAX 3)
    HWI_PROCESSOR_3			= 3 ;   //PROCESSOR 3 OR NUMBER OF PRCESSORS IN SYSTEM (MAX 3)
    HWI_FIND_TOTAL			= 4 ;   //USE TO RETURN TOTALS FOR A PARTICULAR PROCESSOR OF MI's, H48's OR RF.
    //VARIOUS COMM LINKS		///////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
    HWI_MI_LINK			= 1 ;   //LINK FOR MI's ALWAYS 1 AND ONLY ONE.
    HWI_H48_LINK			= 4 ;   //MAKE 0 IF NO H48's
    HWI_KP_LINK_1			= 5 ;   //MAKE 0 IF NOT USED
    HWI_KP_LINK_2			= 6 ;   //MAKE 0 IF NOT USED
    HWI_KP_LINK_3			= 0 ;   //IF NO H48 AND MORE KEYPADS THAN 5 & 6 WILL ALLOW THEN MAKE 4 OTHERWISE LEAVE AS 0.
    HWI_RF_TYPE_DIMMER		= 1 ;   //ADDRESS PORTION THAT INDICATES THE DEVICE IS A RF DIMMER/SWITCH TYPE DEVICE
    HWI_RF_TYPE_KEYPAD		= 2 ;   //ADDRESS PORTION THAT INDICATES THE DEVICE IS A RF KEYPAD TYPE DEVICE
    HWI_RF_TYPE_REPEATER		= 3 ;   //ADDRESS PORTION THAT INDICATES THE DEVICE IS A RF REPEATER TYPE DEVICE
    HWI_RF_LINK 			= 8 ;   //RF DEVICE LINK ALWAYS 8 AND ONLY ONE.
    //OUTPUTS PER INTERFACE		///////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
    HWI_NUM_MI_DEVICES		= 32 ;  //MAX NUMBER OF OUTPUTS PER MI (PANEL) 8 MODULES X 4 OUTPUTS.
    HWI_NUM_H48_DEVICES		= 48 ;  //NUMBER OF DEVICES PER H48 BOARD, SHADES OR MAESTRO DIMMERS.
    HWI_NUM_RF_DEVICES		= 64 ;  //NUMBER ODF DEVICES PER RF LINKS, 1 RF LINK PER PROCESSOR.
    //PROCESSOR 1 GROUP             ///////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
    HWI1_NUM_MIs			= 2 ;  	//0 OR NUMBER OF MI's (PANELS) ON PROCESSOR 1.  (MAX 16)
    HWI1_NUM_H48s			= 2 ;  	//0 OR NUMBER OF H48 BOARDS OR Q96 DEVICES ON PROCESSOR 1.  (MAX 4)
    HWI1_NUM_RF_LINKS		= 0 ;  	//0 OR 1 IF USING RF. ONLY 1 PER PROCESSOR. IF USING MULTIPLE RF PROCESSORS, ADD ANOTHER PROCESSOR GROUP.  (MAX 1)
    //HWI1_MAX_OUTPUTS		= ((HWI1_NUM_MIs * HWI_NUM_MI_DEVICES) + (HWI1_NUM_H48s * HWI_NUM_H48_DEVICES) + (HWI1_NUM_RF_LINKS * HWI_NUM_RF_DEVICES)) ;
    //PROCESSOR 2 GROUP		///////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
    HWI2_NUM_MIs			= 0 ;  	//0 OR NUMBER OF MI's (PANELS) ON PROCESSOR 2.  (MAX 16)
    HWI2_NUM_H48s			= 0 ;  	//0 OR NUMBER OF H48 BOARDS OR Q96 DEVICES ON PROCESSOR 2.  (MAX 4)
    HWI2_NUM_RF_LINKS		= 0 ;  	//0 OR 1 IF USING RF. ONLY 1 PER PROCESSOR. IF USING MULTIPLE RF PROCESSORS, ADD ANOTHER PROCESSOR GROUP.  (MAX 1)
    //HWI2_MAX_OUTPUTS   		= ((HWI2_NUM_MIs * HWI_NUM_MI_DEVICES) + (HWI2_NUM_H48s * HWI_NUM_H48_DEVICES) + (HWI2_NUM_RF_LINKS * HWI_NUM_RF_DEVICES)) ;
    //PROCESSOR 3 GROUP		///////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
    HWI3_NUM_MIs			= 0 ;  	//0 OR NUMBER OF MI's (PANELS) ON PROCESSOR 3.  (MAX 16)
    HWI3_NUM_H48s			= 0 ;  	//0 OR NUMBER OF H48 BOARDS OR Q96 DEVICES ON PROCESSOR 3.  (MAX 4)
    HWI3_NUM_RF_LINKS		= 0 ;  	//0 OR 1 IF USING RF. ONLY 1 PER PROCESSOR. IF USING MULTIPLE RF PROCESSORS.  (MAX 1)
    //HWI3_MAX_OUTPUTS		= ((HWI3_NUM_MIs * HWI_NUM_MI_DEVICES) + (HWI2_NUM_H48s * HWI_NUM_H48_DEVICES) + (HWI3_NUM_RF_LINKS * HWI_NUM_RF_DEVICES)) ;
    //TOTAL SYSTEM ALL PROCESSORS	///////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
    HWI_TOTAL_MI_OUTPUTS		= ((HWI1_NUM_MIs * HWI_NUM_MI_DEVICES) + (HWI2_NUM_MIs * HWI_NUM_MI_DEVICES) + (HWI3_NUM_MIs * HWI_NUM_MI_DEVICES)) ;
    HWI_TOTAL_H48_OUTPUTS		= ((HWI1_NUM_H48s * HWI_NUM_H48_DEVICES) + (HWI2_NUM_H48s * HWI_NUM_H48_DEVICES) + (HWI3_NUM_H48s * HWI_NUM_H48_DEVICES)) ;
    HWI_TOTAL_RF_OUTPUTS		= ((HWI1_NUM_RF_LINKS * HWI_NUM_RF_DEVICES) + (HWI2_NUM_RF_LINKS * HWI_NUM_RF_DEVICES) + (HWI3_NUM_RF_LINKS * HWI_NUM_RF_DEVICES)) ;
    The above compiles fine including the last 3 constants but this next line doesn't:
    HWI_TOTAL_OUTPUTS		= (HWI_TOTAL_MI_OUTPUTS + HWI_TOTAL_H48_OUTPUTS + HWI_TOTAL_RF_OUTPUTS) ;
    The compiler throws this error:
    ERROR: C:\filepath...\Netinx_Code\VAV_HWI.axi(98): C10539: Identifier [HWI_TOTAL_MI_OUTPUTS] undefined
    So I just comment it out and use:
    HWI_TOTAL_OUTPUTS		= 160 ;
    Obviously it defeats the prupose of going through all this crap.
    If they figure it out I'll buy them ein bier at the next Kieler Woche. Actually not since I don't drink anymore and I won't be going to Kiel. The idea is very tempting though.
    vining wrote: »
    Everything compiles fine for me with Netlinx Studio version 3.1.0.374
    Hmmm, i'll have to see what i'm running and update.
    Thanks for checking it.
    Turns out I was running build 3.2.0.418 which is newer and I went ahead and updated to the current version 3.3.525.
    Still didn't work on my system so I started playing around.
    This worked:
    HWI_TOTAL_OUTPUTS_		= ((HWI1_NUM_MIs * HWI_NUM_MI_DEVICES) + (HWI2_NUM_MIs * HWI_NUM_MI_DEVICES) + (HWI3_NUM_MIs * HWI_NUM_MI_DEVICES)
    				   + (HWI1_NUM_H48s * HWI_NUM_H48_DEVICES) + (HWI2_NUM_H48s * HWI_NUM_H48_DEVICES) + (HWI3_NUM_H48s * HWI_NUM_H48_DEVICES)
    				   + (HWI1_NUM_RF_LINKS * HWI_NUM_RF_DEVICES) + (HWI2_NUM_RF_LINKS * HWI_NUM_RF_DEVICES) + (HWI3_NUM_RF_LINKS * HWI_NUM_RF_DEVICES))
    and then this worked:
    HWI_TOTAL_SW_DIM 		= (HWI_TOTAL_MI_OUTPUTS + HWI_TOTAL_H48_OUTPUTS + HWI_TOTAL_RF_OUTPUTS) ;
    so I thought WTF! I then figured maybe because these constants that worked weren't actually used in any later declarations so I went to the first place the non working constant was used and changed it to a working constant:
    CHAR HWI_OUTPUT_NAMES[HWI_TOTAL_SW_DIM ][18]=
    but that didn't break the constant now that is was actually used but I didn't give up and stepped through the code and changed where HWI_TOTAL_OUTPUTS was used one at a time and it turns out that it breaks here.
    DEFINE_TYPE     //_sHWI
    STRUCTURE _sHWI
         _sHWI_Status sStatus ;
         _sHWI_Outputs sOutput[HWI_TOTAL_OUTPUTS] ;//
    if I change that to a constant declared with out a constant used with a math operation it works but if I use a constant declared using a constant and a math operation it doesn't.
    This works:
    TEST_CONSTANT 			= 40 ;
    _sHWI_Outputs sOutput[TEST_CONSTANT] ;
    This works:
    TEST_CONSTANT 			= (10 * 40) ;
    This doesn't:
    HWI_SOME_DUMB_NUM		= 20 ;
    TEST_CONSTANT 			= (HWI_SOME_DUMB_NUM * 40) ;
    Using HWI_TOTAL_OUTPUTS everywhere else in the code works fine but not in the structure "type" declarations. This is an old issue that I gave up on long ago so it doesn't bother me.
    like:
    if(sHWI_UI[iUI_Indx].nSelOut && sHWI_UI[iUI_Indx].nSelOut <= HWI_TOTAL_OUTPUTS)
