Home AMX Control Products
MVP 8400 setup prolem
hello Gents,
during the upload of TP interface suddenly the transfer stop after arround 10 % .
now i coudn't enter to the setup mode even i could see the touch panel from the processor.
could anyone know what could be the solution ? ? ?
thanks
    Most likely, you hit a bad spot on the CF card and it will need to be replaced. If you have an image of a good card of the same firmware revision, you could replace it yourself, but depending on your dealer status, it might be easier to to send it to AMX.
