Led Video Processor 603S+
Hi all,
There's anyone can help me to solve this problem ?
I want to control LED Video Processor which using RS232 port the product is LVP603S+
this is link for your guide
http://www.videowall.cn/en/Downlist.asp
I think this product doesn't have good documentation, maybe someone have experience communicate this product with AMX, please share with me.... I need your help
I have try this command :
send_string (device),"'zzmkxxxxxy',$0D" <-- this command for VGA output
result is "device no respond"
Thanks and regards
Novi Andriyansyah
Indonesian ACE Programmer
  • aksyalaksyal Posts: 21
    please help me guys
  • jjamesjjames Posts: 2,908
    Have you verified the baud rate of 4800?
    Hi James,
    I have Verified the Baud rate with 4800 with this step :
    DATA_EVENT[dvLVP603]
          online:
                send_command dvLVP603,"'SET BAUD 4800,N,8,1,485 disable
          String:
               send_string 0,"'the LVP603 says --> ',data.text"
    for verify the notification from AMX, I was use telnet and notification in netlinx
    from telnet :
    send_command dvLVP603,"'GET BAUD'"
    and I received :
    LVP603 says --> baud 4800,none,8,1,485 disable
    note:
    If I took baud 4800 and I send any command I have no feed back if I send any command
    if I took above baud 38400 and I send any command I have feedback from device FF FF FF FF FF FF
    if I took baud 115200 and I send any command I have feedback from device FF FF a2trdj}FF DF
    so anyone can solve this problem please share with me
    The protocol does not mention a carriage return ($0D), try not removing it.
    For example:
    send_string dvLVP603,'zzmkxxxxxy';
    Also, for code examples, please use the code tags as it makes it much easier to read.
    [$code] <-- remove dollar symbol
    Some code
    [/code]
    jjames wrote: »
    For example:
    Some code
    [/code]
    Hi James,
    Unfortunately, until now I can't control that equipment :(
    I have already moved "$0D" and try all baud rate but I don't have any result
    regards
