R4 problem, help
The remote's keypad is flashing on and off and the touchscreen is not on. I have tried plugging it into the power dock but nothing has happened. remove the battery and plug it again but same issue. Any help would be appreciated
Regards
  • jjamesjjames Posts: 2,908
    Sounds like you need to call AMX for an RMA.
    jjames wrote: »
    Agreed. There is no recovery from that behavior as far as I know. I don't recall what it means exactly, but I've had the same issue, and it required an RMA.
  • a_riot42 wrote: »
    Hi thanks a lot will do that
