Adding Yamaha Module...
I'm trying to get the 1.0.1 Yamaha module loaded on an NI-3000, but I'm having trouble getting the code to compile. Here is what I get after I define the module and all its individual modules:
ERROR: C:\new\HomeNew.axs(408): L20585: Dimension mismatch: [1] vs. [0]
ERROR: C:\new\HomeNew.axs(408): L20211: Type or dimension conflict for [MMENUCMP1]
The modules that I adjusted based on my declarations are as follows:
YAMAHA			= 5001:4:0  //RXV-2700 Theater Receiver
vdvYAMAHA		= 41001:1:0  //for RXV-2700 module
DEFINE_START
define_module 'YamahaRXV2700MenuComponent' mMenuCmp1(vdvYAMAHA, dvTPFam)
define_module 'YamahaRXV2700ModuleComponent' mMdlCmp1(vdvYAMAHA, dvTPFam)
define_module 'YamahaRXV2700PowerComponent' mPwrCmp1(vdvYAMAHA, dvTPFam)
define_module 'YamahaRXV2700PreampComponent' mPreampCmp1(vdvYAMAHA, dvTPFam)
define_module 'YamahaRXV2700SourceSelectComponent' mSrcSelCmp1(vdvYAMAHA, dvTPFam)
define_module 'YamahaRXV2700TunerStationComponent' mTnrStnCmp1(vdvYAMAHA, dvTPFam)
define_module 'YamahaRXV2700VolumeComponent' mVolCmp1(vdvYAMAHA, dvTPFam)
define_module 'YamahaRXV2700DiscDeviceComponent' mDiscDevCmp1(vdvYAMAHA, dvTPFam)
define_module 'YamahaRXV2700DiscTransportComponent' mDiscTranCmp1(vdvYAMAHA, dvTPFam)
//Comm Module
define_module 'Yamaha_RXV2700_Comm_dr1_0_0' mRcvrDev1(vdvYAMAHA, YAMAHA)
It's been quite a while since I needed to use a module, as I've been away from AMX programming for a bit. The module declarations in the demo APW do the same thing. Also, I loaded all the tko files for the respective defined modules above, as well as the .jar file. Is there anything else I need to load besides my code, and a TP file? I can't remember if I need the axs files for anything. All I'm looking to do is to send power, input, and volume commands to this receiver, not even get feedback at this time. Thanks.
  • PhreaKPhreaK Posts: 966
    From your compiler output you need to check on (or around) line 408. There is an attempted assignment of an array to the variable 'MMENUCMP1'.
