UNICODE and Master to Master
Hi guys,
I'm using the tpcontrol XBMC module on an install where I got several masters (NI2100 with 3.60.453)
I need to control the module from several touch panels defined in different masters,
the Panels that are defined in the same master where the module run they work correct where on the panels defined on other masters, the variable text arrive truncated, long only 13 caracters instead 50 or more.
All panels talk to this module thru device port 3.
I presuming the command that the module use is ^UNI.
is there a threshold that regulated this between master to master or do you have an idea how to fix it ?
