C10586: Module instance [MM88] parameter [3] is an expression or a constant error
Hi Guys,
A long while since I last posted here as been working on many projects for the other side. I have been tasked with a new AMX project and produced a couple of modules for this.
When I build the project I get the error list in the subject. Can anyone see what I am obviously missing in the code snippet below?
Many thanks
Here's the main program definition:
DEFINE_DEVICE
pMimo88 = 0:3:0 // IP interface
vtpMimo88 = 32001:1:1 // Virtual mimo88
DEFINE_CONSTANT
char mIpAddress[15] = '192.168.1.80'
DEFINE_MODULE 'mimo88' mM88 (pMimo88, vtpMimo88, mIpAddress) // mimo88 udp connection
Here's the header from the module:
MODULE_NAME = 'mimo88' (DEV dvDevicePort, DEV dUi, CHAR dIpAddress[])
Many thanks
DEFINE_DEVICE
DEFINE_CONSTANT
Thanks for that. Yes it does clear the error. Now curious as to why the ip address has to be declared as a variable.
Inside the Mimo module the value is simply passed into a timeline to execute the following:
IP_CLIENT_OPEN(dvDevicePort.PORT,dIpAddress,dPort,2)
Where dPort is defined as a constant within the module.
Regards
It probably has to do with the way the memory is allocated and the consistency out of the module/inside the module, where something would collapse if you actually intend to assign a value to something declared as a constant out of the module. Perhaps other fellow forum users can shed some more light on the reason for this.
OK I read the help file you suggested and sure enough it does state 'Constants and expressions cannot be used as arguments in the parameter list'
Thankyou for clarifying that.
Have a great week.
Regards
slip
DEFINE_CONSTANT //ARRAYs, DEV, vDEV, UI, IP, INSTANCES, CUSTOMIZE PER INSTALLATION---------------------> DEV dvUI_DVDArry[DVD_NUM_UIs]= { dvTP_DVD_1,//1st floor dvTP_DVD_2,//master dvTP_DVD_3,//purple dvTP_DVD_4,//blue dvTP_DVD_5,//pasqaule's dvTP_DVD_6,//1st fl guest dvTP_DVD_7,//3rd fl tp no DVD dvR4_DVD_1,//media dvR4_DVD_2,//master dvR4_DVD_3,//kitchen dvR4_DVD_4,//bar dvR4_DVD_5,//purple dvR4_DVD_6,//blue dvR4_DVD_7,//tan dvR4_DVD_8 //guest } //DVD INSTANCES CHAR DVD_1 = 1 ; CHAR DVD_2 = 2 ; INTEGER DVD_INSTANCE_Arry[DVD_NUM_DVDs] = { DVD_1, DVD_2 } INTEGER DVD_COMTYPE_Arry[DVD_NUM_DVDs] = //if tv is serial set to DVD_IS_SERIAL, otherwise DVD_IR_NO_LINK //or if IR and you want to link to an IO use DVD_IR_LINK_1 to DVD_IR_LINK_8 for desired IO link {//doesn't matter what these are if set up as IP:PORT controlled devices COMM_IS_SERIAL, COMM_IS_SERIAL } //CHAR COMM_IS_SERIAL = $FF ; //CHAR COMM_IS_IP = $FA ;<---- not really used, if IP, IP:Port is passed in so use serial instead //CHAR COMM_IR_NO_LINK = 0 ; //CHAR COMM_IR_LINK_1 = 1 ; //CHAR COMM_IR_LINK_2 = 2 ; //CHAR COMM_IR_LINK_3 = 3 ; //CHAR COMM_IR_LINK_4 = 4 ; //CHAR COMM_IR_LINK_5 = 5 ; //CHAR COMM_IR_LINK_6 = 6 ; //CHAR COMM_IR_LINK_7 = 7 ; //CHAR COMM_IR_LINK_8 = 8 ; DEV dvDVD_Arry[DVD_NUM_DVDs] = { dvDVD_1, //1 dvDVD_2 //2 } DEV vDVDcom_Arry[DVD_NUM_DVDs] = { vDVDcom_1, //1 vDVDcom_2 //2 } CHAR DVD_IP_n_PORT[DVD_NUM_DVDs][26] = //if using a serial server {//these must be empty if not ip '192.168.9.117:23',// IP & PORT '' } .................... DEFINE_MODULE 'VAV_Oppo_DVD_Mod,Rev0' Oppo_1(vDVDcom_Arry[DVD_1],dvDVD_Arry[DVD_1],DVD_INSTANCE_Arry[DVD_1],DVD_IP_n_PORT[DVD_1],DVD_COMTYPE_Arry[DVD_1],nDVD_IP_Type,nDVD_DeBug)Everything passed into the module is global between the main line and the module. Meaning if you change the value of something in the module the new value available to the mainline as well.
Passing a constant into a variable via a module call would then be illegal.
CJ Butcher
Software Development manager
CineTouch
