PROGRAM_NAME='WakeOnLan,Rev 0'
DEFINE_DEVICE
TP=10001:1:0
DEFINE_VARIABLE
slong Result // if 0 then Port opened
integer connected
MAC[6] // MAC-Adress of the Computers Network-card (6 Bytes)
START[6] // 6 x $FF, Part of the 'Magic Packet'
DEFINE_START
MAC="$00,$B0,$D0,$A0,$C2,$DE" //Example
START="$FF,$FF,$FF,$FF,$FF,$FF"
Result=99
DEFINE_PROGRAM
Push[tp,1]
Result=IP_CLIENT_OPEN (2,'255.255.255.255', 2304, 2) // Open port with Broadcast adress and Port=2304 , UDP
if(result=0)
connected=1
result=99
Push[tp,2]
IP_SERVER_CLOSE (2)
connected=0
Push[tp,3] // Magic Packet: 6 x $FF, 16 x Mac-Adress
send_string 0:2:1,"START,MAC,MAC,MAC,MAC,MAC,MAC,MAC,MAC,MAC,MAC,MAC,MAC,MAC,MAC,MAC,MAC" }
[tp,1]=connected
[tp,2]=(!connected)
I had issues using MAC addresses from a string (eg sMACaddress = '01A623B745C8'), then discovered that if I converted each hex set to an integer using HEXTOI, I could send them instead, after recombining them into a single string:
(Based on the MAC above)
nHexToNumber[1] = HEXTOI('01')
nHexToNumber[2] = HEXTOI('A6')
nHexToNumber[6] = HEXTOI('C8')
SEND_STRING 0:2:0,"START,sParsedMACAddress,sParsedMACAddress,
sParsedMACAddress,sParsedMACAddress,sParsedMACAddress,sParsedMACAddress,
sParsedMACAddress,sParsedMACAddress"
As far as I can tell, the problem was that as a string, each hex set ('01', 'A6', etc) is treated as 2 bytes ('0'+'1', 'A'+'6"...) giving 12 in total, but the MAC address can only be 6. By converting to an integer, each number is sent as a single byte (MAC above translates to 1, 166, 35, 183, 69, 200)
At least, that's my understanding of it all - happy to get further clarification.
May not be the cleanest way to do it - but at least I know it works!
Try this, it works:
Please try it....
Regards, Leon
Thanks for sharing.
Cheers,
Charles
Adam
I have a VDR (Reelbox) with the MAC Aresse: 00-1B-73-71-64-58
Is it really MAC = "$00,$1B,$73, $71, $64, $58"
Unfortunately does not work
From the computer works with Windows 00-1B-73-71-64-58 (program WAKEON)
Thank you
sParsedMACAddress = "nHexToNumber[1],nHexToNumber[2],nHexToNumber[3],
nHexToNumber[4],nHexToNumber[5],nHexToNumber[6]"
Sendstring's method works for me in 2019, long live netlinx
changed port to port 9 for my network though !
If you are trying to use the WoL module in 2024, I might have some help for you.
The module is looking for a Char value, so give it one.
I found this works for the mac address:
Char cMac_Hex[6] = {$BE,$EF,$70,$FE,$ED,$FF}
And this doesn't:
integer cMac_Hex[6] = {$BE,$EF,$70,$FE,$ED,$FF}
