Home AMX Technical Discussion
Question regarding Online/Offline of a duet module
Hi All,
i have programmed a basic system with a projector Nec Controlled by Ethernet.
Everything works except when i upload a new program the module always tell the device is offline until i disconnect and reconnect the lan cable.
can i check if the status device offline is actived during a delay to disconnect and reconnect the communication between the device and the processor. and how can i do that ?
Thanks for help.
  • PhreaKPhreaK Posts: 966
    Are you using a module that you have built yourself?
  • RaphayoRaphayo Posts: 111
    no, use a module from the AMX database
    The module may have documentation. It might have the info you need. Quite often there is a channel on the virtual device used to indicate whether or not the device is communicating. There also may be a REINIT command to retrt communication.
