SocketConnection Error
Hi,
i have a system with a NEC Projector control via IP.
When i reboot the processor, I was unable to communicate with the device.
if i disconnect the lan wire on the projector the communication start between the projector and the processor.
I read other post about problem like that and i'm able to ping the projector with the AMX Processor.
Any suggestion from you guys
Line 1 (13:16:36):: CICSPTCP Rx connection to 192.168.1.110 has been closed locally or by peer Line 2 (13:16:36):: ICSPTCPRx1::CloseSocket: Closing Socket Line 3 (13:16:54):: ERROR: NEC_NP600: [] - SocketConnection: createSocket: IO exception Line 4 (13:16:54):: ERROR: NEC_NP600: [] - SocketConnection: createSocket: socket create failed Line 5 (13:16:54):: NEC_NP600: handleSocketStatus(): socket failed connect
this problem can be because the Master or the Device doesn´t close the socket properly before the reset.
When you say "reboot the processor", you mean rebooting the Master or the Projector?
In any case,
First ensure that before you make the reset, the socket is close properly (you know, ip_client_close)
If you can not close the connection properly (maybe a network failure), i suggest to close the connection each time before trying to open a new one:
