Precis DSP 18x18 - Loud Pop on Power Cycle
My first time working with a Precis switcher and whenever I switch the power off/on or the system loses power, there is a loud pop through the speakers when going off and again when turning the switcher back on.
Is this normal behavior?
Jim
Jim
Easiest to resolve by having the amps on a separate switched power channel so that they can be shut down first as previously mentioned.
There are separate issues here with the switcher and amps. In general the following options are available in order of preference:
- Choose amps with mains fail detection that shut off the outputs as soon as the mains power is cut
- Put the amps on a separate switched power channel and shut them down before the equipment feeding them
- Use a line isolation transformer at the inputs to the amp
