Firmware Update Failed, Not Enough Memory
Trying to update my NI-3100 running 3.41.414 to 3.60.453. When I try I get this message
Transfer Aborted - Not enough memory available on device to hold file.
Memory required: 458967  Memory Available 0
Per the readme
Requires NI-Device firmware version of 1.30.8 or greater to fully utilize the enhancements.
If NI-Device version 1.30.8 or later is loaded before this master firmware version, the
integrated device (5001) will be unavailable until the master side firmware is upgraded.
I am running 1.30.8
What should I check?
  • DavidRDavidR Posts: 62
    update to the system number not the device number... 1.30.8 is device firmware. you need to send master firmware to the system number or system 0
  • jabramsonjabramson Posts: 106
    DavidR wrote: »
    Sonnuva...Thanks (Hangs head in shame)
