Passing Device To Function
I'm sure this is something very simple. I'm trying to pass a device to a function but I am getting a Dimension Mismatch and type mismatch error on the function call side (not the function processing side)
Function Call
MY_FUNCTION(dvTOSEND)  //Error is with this code
Function Code
DEFINE_FUNCTION MY_FUNCTION(DEV dDEVICE[])
    send_string dDEVICE, "String to Send"
    Take out the [ and ].
    The brackets imply you're sending a DEV array
  • amclainamclain Posts: 41
    The compiler is complaining because you've told the function to expect an array of devices, signified with the brackets on dDevice[]. If you drop the brackets it should work the way you want it to, accepting a single device.
    Like this:
    DEFINE_FUNCTION MY_FUNCTION(DEV dDEVICE)
  • jabramsonjabramson Posts: 106
    That worked, thanks (I knew it was something simple).
