WAIT_UNTIL with a function to check Variable
I have not had a chance to test this, I just thought I would ask some of the more experienced among us.
Thank you, in advance, for any input.
I am curious about how WAIT_UNTIL works with a function as the check.
i.e. WAIT_UNTIL (System_Ready() == True) 'Wait_Until_System_Ready'
Will the Function be called more than once?
Define_Function Integer System_Ready()
Stack_Var Integer Result;
Result = True;
if ( (bSystem_Ready and other Variables) == True;
Result = True;
return Result;
Define_Function DoSomethingWhenSystemIsReady()
//Do Something
Result = True;
Result = True;
return Result;
//Do Something
This looks a little suspicious to me and I would probably create a separate variable, say, nSystemReady, and then in my DEFINE_PROGRAM put something like
wait 10 if(nSystemReady == false){ if(System_Ready()){ nSystemReady = true; // do stuff } }that way we have control over how often the SystemReady flags are checked.but DEFINE_PROGRAM does not get run.
CORRECTION: DEFINE_PROGRAM does get run.
That is OK for me as I do not do much in DEFINE_PROGRAM.
Thank you all for your input.
Thank you Vining, for the suggestion for the TIMED_WAIT_UNTIL.
Results from test:
GET STATUS
Line 1 (15:43:56):: Status:
Line 2 (15:43:56):: SystemOn=0
Line 3 (15:43:56):: DisplayPower=0
RUN TIMED_WAIT_UNTIL
Line 4 (15:44:01):: WAIT_UNTIL Test
Line 5 (15:44:01):: Checking to see if System Is Ready
Line 6 (15:44:01):: Checking to see if System Is Ready
Line 7 (15:44:01):: Checking to see if System Is Ready
Line 8 (15:44:01):: Checking to see if System Is Ready
Line 9 (15:44:02):: Checking to see if System Is Ready
Line 10 (15:44:02):: Checking to see if System Is Ready
Line 11 (15:44:03):: Checking to see if System Is Ready
Line 12 (15:44:03):: Checking to see if System Is Ready
Line 13 (15:44:04):: Checking to see if System Is Ready
Line 14 (15:44:04):: Checking to see if System Is Ready
Line 15 (15:44:05):: Checking to see if System Is Ready
Line 16 (15:44:05):: Checking to see if System Is Ready
Line 17 (15:44:06):: Checking to see if System Is Ready
Line 18 (15:44:06):: Checking to see if System Is Ready
Line 19 (15:44:07):: Checking to see if System Is Ready
Line 20 (15:44:07):: Checking to see if System Is Ready
Line 21 (15:44:08):: Checking to see if System Is Ready
Line 22 (15:44:08):: Checking to see if System Is Ready
Line 23 (15:44:09):: Checking to see if System Is Ready
Line 24 (15:44:09):: Checking to see if System Is Ready
Line 25 (15:44:10):: Checking to see if System Is Ready
Line 26 (15:44:10):: Checking to see if System Is Ready
Line 27 (15:44:11):: Checking to see if System Is Ready
Line 28 (15:44:11):: Checking to see if System Is Ready
Line 29 (15:44:12):: Checking to see if System Is Ready
Line 30 (15:44:12):: Checking to see if System Is Ready
Line 31 (15:44:13):: Checking to see if System Is Ready
Line 32 (15:44:13):: Checking to see if System Is Ready
Line 33 (15:44:14):: Checking to see if System Is Ready
Line 34 (15:44:14):: Checking to see if System Is Ready
Line 35 (15:44:15):: Checking to see if System Is Ready
Line 36 (15:44:15):: Checking to see if System Is Ready
Line 37 (15:44:16):: Checking to see if System Is Ready
Line 38 (15:44:16):: Checking to see if System Is Ready
Line 39 (15:44:17):: Checking to see if System Is Ready
Line 40 (15:44:17):: Checking to see if System Is Ready
Line 41 (15:44:18):: Checking to see if System Is Ready
Line 42 (15:44:18):: Checking to see if System Is Ready
Line 43 (15:44:19):: Checking to see if System Is Ready
Line 44 (15:44:19):: Checking to see if System Is Ready
Line 45 (15:44:20):: Checking to see if System Is Ready
Line 46 (15:44:20):: Checking to see if System Is Ready
Line 47 (15:44:21):: Checking to see if System Is Ready
Line 48 (15:44:21):: Checking to see if System Is Ready
Line 49 (15:44:22):: Checking to see if System Is Ready
Line 50 (15:44:22):: Checking to see if System Is Ready
Line 51 (15:44:23):: Checking to see if System Is Ready
Line 52 (15:44:23):: Checking to see if System Is Ready
Line 53 (15:44:24):: Checking to see if System Is Ready
Line 54 (15:44:24):: Checking to see if System Is Ready
Line 55 (15:44:25):: Checking to see if System Is Ready
Line 56 (15:44:25):: Checking to see if System Is Ready
Line 57 (15:44:26):: Checking to see if System Is Ready
Line 58 (15:44:26):: Checking to see if System Is Ready
Line 59 (15:44:27):: Checking to see if System Is Ready
Line 60 (15:44:27):: Checking to see if System Is Ready
Line 61 (15:44:28):: Checking to see if System Is Ready
Line 62 (15:44:28):: Checking to see if System Is Ready
Line 63 (15:44:29):: Checking to see if System Is Ready
Line 64 (15:44:29):: Checking to see if System Is Ready
Line 65 (15:44:30):: Checking to see if System Is Ready
Line 66 (15:44:30):: Checking to see if System Is Ready
Line 67 (15:44:31):: Checking to see if System Is Ready
Line 68 (15:44:31):: Checking to see if System Is Ready
Line 69 (15:44:31):: Checking to see if System Is Ready
Line 70 (15:44:31):: Checking to see if System Is Ready
TIMED OUT
GET STATUS
Line 71 (15:48:46):: Status:
Line 72 (15:48:46):: SystemOn=0
Line 73 (15:48:46):: DisplayPower=0
Line 74 (15:48:56):: WAIT_UNTIL Test
Line 75 (15:48:56):: Checking to see if System Is Ready
Line 76 (15:48:56):: Checking to see if System Is Ready
Line 77 (15:48:56):: Checking to see if System Is Ready
Line 78 (15:48:56):: Checking to see if System Is Ready
Line 79 (15:48:57):: Checking to see if System Is Ready
Line 80 (15:48:57):: Checking to see if System Is Ready
Line 81 (15:48:57):: Checking to see if System Is Ready
SET BOTH VARS ON
TIMED_WAIT_UNTIL executes code
Line 82 (15:48:57):: System Is Ready
GET STATUS
Line 83 (15:48:57):: Status:
Line 84 (15:48:57):: SystemOn=1
Line 85 (15:48:57):: DisplayPower=1
TP has 6 buttons
1:Set VARS ON
2:Set VARS OFF
3:Toggle System Var
4:Toggle Display Var
5:Send Status
6:Run TIMED_WAIT UNTIL
Code:
PROGRAM_NAME='TestSystem'
(* FILE CREATED ON: 09/26/2012 AT: 14:36:14 *)
(* FILE_LAST_MODIFIED_ON: 09/26/2012 AT: 15:47:31 *)
(* DEVICE NUMBER DEFINITIONS GO BELOW *)
DEFINE_DEVICE
dvTP1Main = 10001:1:1;//Misc System Control
(* CONSTANT DEFINITIONS GO BELOW *)
DEFINE_CONSTANT
SYSTEM_READY_TIMEOUT = 300;//30 Seconds
(* VARIABLE DEFINITIONS GO BELOW *)
DEFINE_VARIABLE
VOLATILE Integer btnsTest [] =
1, 2, 3, 4, 5, 6
VOLATILE Integer SystemOn;
VOLATILE Integer DisplayPower;
(* THE FUNCTIONS GO BELOW *)
Define_Function Integer TSystem_IsReady()
Result = True;
Send_String 0, 'Checking to see if System Is Ready';
if ( !SystemOn || !DisplayPower)
Result = False;
return Result;
(* THE EVENTS GO BELOW *)
DEFINE_EVENT
Button_Event [dvTP1Main, btnsTest]
PUSH:
Switch ( Button.Input.Channel )
Case 1:
SystemOn = True;
DisplayPower = True;
Break;
Case 2:
SystemOn = False;
DisplayPower = False;
Break;
Case 3:
SystemOn = !SystemOn;
Break;
Case 4:
DisplayPower = !DisplayPower;
Break;
Case 5:
Send_String 0, "'Status:'";
Send_String 0, "'SystemOn=', itoa(SystemOn)";
Send_String 0, "'DisplayPower=', itoa(DisplayPower)";
Break;
Case 6:
Send_String 0, 'WAIT_UNTIL Test';
CANCEL_WAIT_UNTIL 'WAIT_UNTIL Test';
TIMED_WAIT_UNTIL ( TSystem_IsReady() )
SYSTEM_READY_TIMEOUT 'WAIT_UNTIL Test'
Send_String 0, 'System Is Ready';
Break;
(* STARTUP CODE GOES BELOW *)
DEFINE_START
SystemOn = False;
(* THE ACTUAL PROGRAM GOES BELOW *)
DEFINE_PROGRAM
Wait 5
Send_String 0, 'Running DEFINE_PROGRAM';
